Om man skulle få för sig att skaffa en C3...
Re: Om man skulle få för sig att skaffa en C3...
Sugen på att skaffa mig ett riktigt fint chassi. Eller rättare sagt en
proostreet camaro 69 utan motor å låda typ.
Att bygga ngt kul av.
Typ 632a med 14/71a før gatan.(blir nog att køra obesiktigat då9
Får jag ngt vettigt bud på vetten så blir det nog så.
Jag har fått prislistan för nya chassien till C3orna från http://www.streetshopinc.com/
Mycket fina grejor ser det ut som.
- 53-62 Chassis, C4 based, Incl. Black PC and Suspension Modifications $7 530
63-67 Chassis, C4 based, Incl. Black PC and Suspension Modifications $7 420
68-82 Chassis, C4 based, Incl. Black PC and Suspension Modifications $7 420
53-62 Chassis, C6 based, Incl. Black PC and Suspension Modifications $8 910
63-67 Chassis, C6 based, Incl. Black PC and Suspension Modifications $8 800
68-82 Chassis, C6 based, Incl. Black PC and Suspension Modifications $8 800
Factory-type Frame Mounted Battery Tray, C1 $109
Install Provision for Factory Battery Tray, C2, Specify LH or RH Included
AGR Power Rack & Pinion w/ New Tie Rod Ends $369
Custom 1" Front Sway Bar w/ Urethane Bushings & Billet Endlinks $215
Custom 7/8" Rear Sway w/ Urethane Bushings & Billet Endlinks $245
Steering Shaft Adapter, Mustang Rack to Corvette Column $275
Billet Lower Coil-Over Mount, pr, Rear (Required on 63-82 Chassis)** $130
QA1 Aluminum Coil-Over Shocks, Single Adjustable, w/ Spring, Front $426
QA1 Aluminum Coil-Over Shocks, Single Adjustable, w/ Spring, Rear $382
89-96 Corvette Front Suspension, Remanufactured $1 380
84-96 Corvette Dana 44, Remanufactured, Includes HD Half-Shafts $3 995
"Super Duty" Dana 44 w/ Street Shop Billet Suspension $4 495
Billet Aluminum Adjustable Camber Bar, pr. $105
Custom Rear Toe Assembly (Reqd.on 53-62 C4 based Chassis & SD D44) * $325
New GM C5/6 Front and Rear Suspension Inquire
Street Shop Exclusive C6 M50 Rear and HD Half-shaft Assy. $3 825
Stainless Steel Brake System w/ Stainless Braided Hoses $424
Stainless Steel Fuel Line w/ AN Fittings $176
Stainless Steel Fuel Return Line w/ AN Fittings for EFI $176
LS Fuel System; Includes Single SS hardline plus filter and hoses $352
Rebuilt Calipers w/ New Brake pads and New OEM-style Rotors Inquire
Upgrade to 13" Front Brakes $150
Upgrade to Drilled/Slotted Rotors $275
Wilwood Brake Kits Front and Rear w/ Parking Brake, Starting at $1 800
New PBR Caliper Brake Kit w/ Pads 13" front, Std rear (C4 Requires C6 Rear Brake Adapters, Calipers and Rotors) $995
Street Shop Exclusive C56 Rear E-Brake Kit for C4 Spindles, complete $695
Drilled/Slotted Rotor Kit for PBR Calipers and C6 Rear E-brake Assy. $475
LS Accessory Drive Kit; A/C, P/S, Alt. (ADD $500 for Chrome/Polish) $2 850
Power Steering Hose Kit $120
Emergency Brake Cable Kit $156
GMPP Crate Engines and Transmissions Inquire
Tremec TKO 5 Speed Transmission Kit Inquire
Thomas
Thomas
Altså.. En 1" swaybar.. Då det finns en 1-1/8" att tillgå..
Sen bör du lägga till Dick Guldstrans kulleder till den för max fränhet och minst glapp..
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
Det är mycket att tänka på. 68-69 har snyggaste linjerna men från 78 kom första riktiga aerodynamiken och motorkylningen.
Ska man satsa på snyggt eller smart?
Thomas
Thomas
1980 - 1982 är den snyggaste coupe Corvetten någonsin! Den hade dock varit ännu snyggare med Kromade stötfångare från 1968 - 1972! Så en kombination av dessa modeller hade varit helt perfekt! Om du inte ska ha en cab för då är det 1968 - 1972 som gäller!
Detta är vad jag tycker! Men det skulle naturligtvis vara lagstadgat!
1980:
Jag har bara ägt cabbar de senaste 12 åren men eftersom det här är tänkt att bli en racebil så är det coupe som gäller.
Thomas
Thomas
Coupe, då finns bara 3 årsmodeller att välja på, en sådan som den röda!
Kan du förklara detta för en som inte förstår vad som hände med "motorkylningen" 1978?Hejdarn skrev: från 78 kom första riktiga motorkylningen.
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
Det är ingen skillnad på yttre motor kylning , kan va att
han menar kanske att från -78a tog den in kall luft framför kylaren
in i luftburken via plastluftkanal en på 78an från 79an dubbelkanal
/Christer
Det kan vara så enkelt att jag inte vet vad jag pratar om.
Jag håller på och lär mig om de här bilarna nu och läser egentligen bara tech specarna på de olika C3orna.
Drag koefficienten minskade från .503 till .443 och luftflödet till motorkylaren ökade med 50% 1980.
Så jag läste fel och ni hade rätt.
Just nu håller jag på och reder ut regelverket kring ombyggnad av fordon och amatörbyggt fordon och det är inte helt självklart vad som är vad och hur mycket man får ändra utan att åka på den lusiga begränsningen på max 200 hk per ton.
Det är inget kul att bygga en bil och sedan inte få regga den.
Thomas
Thomas
Dags att göra slag i saken..?
Jag ställer upp med dragbil och trailer för hämtning.
http://www.blocket.se/ostergotland/Corv ... ?ca=11&w=3
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
Bra pris för en -79a , kan kanske vara fördel om man ska bygga bur med den bakrutan !
/Christer
/Christer
/Christer
Den ska jag titta på! Tack för tipset, ringer direkt.
Thomas
Thomas
Det är en 79'a som skall vara i bra skick utan rost i ram och med sprickfri kaross.
4-växlad låda och ingen motor. Den är typad med en 235 hp L82 motor och bilen har tydligen stått i 25 år.
Till rätt pris så kan det absolut vara en grundplåt att börja med så jag ska titta på den imorgon.
Nu var det en kille före som var spekulant så vi får se om den blir krängd.
Någon som vill tycka till om vad den skulle kunna betinga för pris?
Thomas
Thomas
Som jag själv brukar säja som då jag säljer något.. Priset står i annonsen och är priset för högt är det fel objekt..
50 lakan är ett struntpris för en Vette om den inte är riktigt skrotig.
Jag har dragbil och trailer om du vill ha hämthjälp Thomes.
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
Ricky skrev:Som jag själv brukar säja som då jag säljer något.. Priset står i annonsen och är priset för högt är det fel objekt..![]()
Tack för det Ricky.
Nu är det bara ett par mil från där jag bor så det borde gå att lösa.
Alla vet inte vad ett ett vettigt värde är på det som säljs och jag kan inte C3 tillräckligt än för att ha ett bra grepp.
50 papp är inte mycket för en bil men är det rätt peng för ett chassie utan motor som inte rullat på 25 år?
Ja, inte vet jag. Ska ringa igen idag och se om den är kvar så får jag titta på den.
Thomas
Thomas
Ja, han svarar inte i telefon idag så jag antar att den blev såld till mannen från Skänninge igår.Chrippe skrev:Annonsen är borta från Blocket
Det var en före och tittade på den som skulle få ok från tanten att handla så det fick han förmodligen.
Ricky ringde och snackade en bra stund och nu när jag fick bolla lite tankar med en C3 åkare/byggare så var det flera poletter som ramlade ner.
Stort tack Ricky!
Det jag tror jag letar efter är idealt en besiktningsbar 71-73 big block (med eller utan motor) coupe med manuell växellåda. Sidepipes är extra plus.
Pekka Nyström är ju ett namn som dyker upp hela tiden så jag ska se om han vill prata en stund och kanske lära mig något.
Thomas
Thomas
Hej Thomas!
Har du kollat in den här c3 på blocket? Man ska inte stirra sig blind på priset
Det går alltid att lägga ett bud
http://www.blocket.se/vasternorrland/Co ... ?ca=11&w=3
Alt.2http://www.blocket.se/vasterbotten/Chev ... ?ca=11&w=3
Eller den här http://www.blocket.se/malmo/Corvette_tr ... ?ca=11&w=3
Lycka till med bilköpet
3526/CORVETTE le mans
https://youtu.be/IwrkFroReW8
Alt 2 och 3 var nya för mig men jag har tittat på alt 1 en stund och den har varit ute länge nu.
Ser inte alls dum ut tycker jag. Tvåan alltså, trean kan bli lite knepig att få fart på.
Thomas
Thomas
Hittade den är c3 68 Big block
http://www.youtube.com/watch?v=XWc2f-XQ4Uc
Kanske för fin att skära i
Ingen C3 men en sjysst C4 att sopa rent med kan ju inte heller vara fel..?
http://www.nitroz.se/NitrozAnnonsNY/vie ... 749#toppen
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
Det är nog samma som finns på Blocket !
Sen var det ju rätt färg oxå !
Motorbyte / trimning har diskuterats tidigare i tråden.
Det som inte har nämnts är att du genom att välja en lämplig std motor faktiskt kan tävla i en existerande serie: SPVM där man kör enligt bl.a. Roadsport & CCS RACING CUP reglementet.
Att däremot bygga en egen motor godkänd för roadsport torde vara ganska svårt/dyrt och om jag känner dig rätt kommer du för eller senare vilja tävla
6.20.2 Modifierade motorer sid 22
http://web.sbf.se/regler/up/4/RA_Sportvagnsregl.pdf
CCS CORVETTE CUP;
CCS TA SERIEN;
CCS CORVETTE CUP;
CCS TA SERIEN;
Lite Off Topic kanske men en kommentar till Roadsport reglementet..
Det är i princip omöjligt att köra i Roadsport med en Corvette om den råkar vara trimmad.
Jag har själv förr sneglat på detta och min bil kommer aldrig att tillåtas pga att jag har en rullkam, även om min motor inte utvecklar mer effekt än andra standardmonterade corvettemotorer.
Samtidigt tillåter man hembyggen i form av i stort sett rena racebilar såsom Super7 och liknande.
Helt sjukt!
Jag antar att man inte är intresserad av mångfald i den Roadsport.
Helt sjukt!
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
Du har helt rätt och det är därför jag föreslår Tomas att satsa på en otrimmad std motor.Ricky skrev:Det är i princip omöjligt att köra i Roadsport med en Corvette om den råkar vara trimmad.
Inom SPVM som är den förening som är den mest aktiva inom Roadsport pågår en ständig diskussion om reglementen och man för även en dialog med SBF så att det sker uppdateringar utav reglementena.
Om vi är intresserade utav att påverka SBFs roadsport reglemente bör vi arbeta för att få igång SBF racingen inom CCS.
CCS CORVETTE CUP;
CCS TA SERIEN;
CCS CORVETTE CUP;
CCS TA SERIEN;
Vilka är "vi"?745 skrev: Om vi är intresserade utav att påverka SBFs roadsport reglemente bör vi arbeta för att få igång SBF racingen inom CCS.
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
Vi = CCSRicky skrev:Vilka är "vi"?745 skrev: Om vi är intresserade utav att påverka SBFs roadsport reglemente bör vi arbeta för att få igång SBF racingen inom CCS.
CCS CORVETTE CUP;
CCS TA SERIEN;
CCS CORVETTE CUP;
CCS TA SERIEN;
Med tanke på pågående diskussion verkar det inte som "vi" kan påverka så mycket..745 skrev: Vi = CCS
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
2011 - KM Oldies
2012 - KM Oldies
2013 - KM Oldies
2014 - KM Oldies
